SSEP 500 sewage pump -- external water sources or requirements ??
  • SSEP 500 sewage pump -- external water sources or requirements ??
    I just bought a home with the SSEP 500 sewage pump installed
    There is a water line going underground in the basement floor above & towards the pump
    the water from this line runs forever -- at least a few hours or as long as I let it, without shutting off
    - there is no visible evidence where this water goes
    I do not see the water level in the pump increasing or any movement of water when this is running?/
    the basement floor is not damper or wet, does not show signs of water coming up
    does the pump require external ie fresh water to maintain a certain level, dilution, to help pump, or for any reason ??
    does this water=line have anything to do with the pump?
    or any ideas on this type of problem?? solution-s?? ?
    thank you
    jaguar
