Eljer touch flush ball leaks
  • Eljer touch flush ball leaks
    I have been using and occasionally working on this Eljer touch flush toilet since 1978. A few years ago, I replaced the ball which may have been the original. Recently I noticed the tank refilling regularly and noticed then that water was dribbling down slowly into the tank. I pulled the fill valve overflow and it wasn't leaking any water so I went and bought a new ball. After installing it I still have the same problem. I believe that the opening it covers has become rough and water is leaking around it.
    If this is the problem, what can I do to fix the surface and have it seal again?
    Thx...
