Eljer touch flush ball leaks
  • Eljer touch flush ball leaks
    I have a touch flush that I've been repairing since 1978. After replacing the ball several years ago, I noticed recently that it is losing a little water into the bowl constantly. After checking the overflow tube from the fill valve and determining that the fill valve is not leaking, I went and bought a new ball for it and after installing it I still have the same problem. I believe that it is possible that the seat for the ball is rough and letting water slip by.
    Is this possible? If so what can I do to improve the seal? If not, what should I check for?
    Thx...
