gas line to pool heater - short run
    Re: gas line to pool heater - short run
    Originally posted by davidryan8100 View Post
    I recently had the exact same problem. I ran a 3/4" gas line about 60' underground to a 350btu pool heater.I read out interesting and informative ideas.This will be helpful for me.Thanks everyone...
    Then be aware that the line you installed, unless it's high pressure, is woefully undersized for your application. A basic sizing chart shows you will only get approximately 138,000 btu across that distance using low pressure gas.
    http://home.mchsi.com/~gweidner/pipe...g-chart-ng.pdf
