How To Post Images
See more
See less
What would a plumber use in thier own house?
  • What would a plumber use in thier own house?
    If you were building a new home to live in forever (not sell), what type of supply pipe would you use? I would start a poll, but I would probably miss a few choices in the response section.
    I asked one plumber I took an evening class from, and he was very "pro-copper", though he showed us a variety of alternatives. As a homeowner, I have had both PEX (crimp ring style) and copper. Havn't really had any issues with either, but I also didn't install the systems. His argument was that copper is very well proven, and has withstood the test of time.
    What's your opinion?
    Re: What would a plumber use in thier own house?
    TYpe L copper for in the home, type K copper for underground. I also would plumb my DWV system in copper (type L the DWV Copper is junk) and Cast Iron (lead and oakem joints)
      It really depends on the environment it is to be installed in. Assuming all conditions are right copper would be first.
        When I build my next house, I'll use as much Wirsbo as I can and include their fire protection system in the design.
          Type K for the water service .xh cast iron for the ground works. no hub for the waste and vent with L copper for the wet loops . cast iron tubs and whirpools ...Or plastic everything..2lb system for the gas with wardlex gastite or blk steel dep. if anybody was borrowing the power vise at the time
            Man your hardcore.....I like it!!!!
            Derek
              Can we beat a dead horse any harder?
              How many pex vs. the world threads do we really need?
                ...no votes for galvanized through-out?
                  I will be the first to admit I am not that good of a plumber to acuratly cut and thread galcanized through out a home.
                    Ron, why on earth would you want to install steel when you could cut and thread sch 40 brass pipe.
                    You would use copper on your waste? Whoa momma. Imagine having to pay for 3" and 4" type L copper in full lengths?
                    The only house I built for myself was in 1988 or so. I used no hub on the waste, PVC on the vents, and type L copper for all the water.
                      Run a copper home run manifold system for water, cast iron no hub above slab, pvc below slab and cleanouts everywhere.
                        I don't like relying on rubber components when they are buried in the wall. If I were to run CI for waste and vent, it would be service weight with lead and oakum joints.
                        I think that Ron was implying that the 1.5" and 2" lines would be copper and the 4" would be CI.
                        For water I would use type L copper unless the water was really aggressive. Then I would probably use pex (the viega stainless coated stuff).
                        For waste I would use Service Weight CI with lead and oakum joints for all the soil stacks and underground (XH if I could get it easy enough) not only for the quality but also to keep noise down....but I would probably use PVC for the vents as well as sink and tub/shower drains.
                          Public water - Either Copper or Pex for water
                          Well - Pex would be my first choice, followed by copper and a water softenfer/acid neutralizer(if need be) and whole house filter
                          Drain lines - PVC schedule 40 throughout the house and to the main. I would take the smooth walls over the porous walls everyday of the week and twice on sunday.
                            Hey he's right, most die hard plumbing vet are all going to say good old fashion copper. Its what they know and its proven to withstand time. All the new stuff hasn't proven itself yet, and most gimmick before it have all been disproven ala' Polybutlene pipe. So definetly I would build home with copper all the way with a water softner/filter at the main valve of course. But hands down L copper the way to go.
                            Wise man said "Hot on the left, cold on the right,
                            crap flows downhill, and checks come on Friday"
                              I used Pex with copper stub outs for the angle stops.
