Gas pipe lr nipple n coupling
  • Gas pipe lr nipple n coupling
    Is there anywhere in Ca. that won't let this be used uncovered in a structure ? Example - Garage or crawl space. Thanks
    Re: Gas pipe lr nipple n coupling
    Interesting question. Is Dan on your case again, Kevin? The answer hinges on the AHJ's definition of a concealed location. (Per CPC 2010 Section 1211.3.2 Where gas piping is to be concealed....right and left couplings....shall not be used) Is a garage concealed? Probably not. Is a crawl space? Since the literal definition of conceal is "to place out of sight", then I'd say a crawl space is a place where something is out of sight.
      No ,just curious. SF Is expensive,Gas,
      tools, and Build. dept. is difficult and very expensive. Don't curb Your tires on a slight Hill $55. I've been using LR In crawlers and open garages with out Question for Years. Thanks Scott
