chamfer short pieces of CPVC pipe
  • chamfer short pieces of CPVC pipe
    Hello,
    I am wondering how I can chamfer the outside of short pieces of CPVC pipe - these are only 1.5 inches long and 1 inch diameter. I have several hundred to do at a time, about one batch per month.
    I used these pieces to connect Tees, elbows, connectors, etc. The pieces are cut with a tube cutter but the outside edge is sharp and will push up some CPVC during solvent cememting.
    I can bevell the inside using an 82 degrees countersink in a drill press - very fast and clean finish.
    I just have no good ideas to do the outside.
    Any thoughts from anyone?
    Thanks, Ron
