old moen balancing spool removal
  • old moen balancing spool removal
    can anyone explain how to remove the balancing spool on an old moen shower body. i replaced the 1200 cartridge and am only getting hot water now. i was able to remove the large slotted screw but only part of the balancing spool cartrdge came out. any help would be greatly appreciated.
    Re: old moen balancing spool removal
    try tapping on the end with a hammer. the piston is stuck and not moving. or soak in vinegar and tap.
      Rick, soak in vinegar. Please explain more???? Is this something that you were taught.
        the balancing spool is a piston and cylinder with tight tolerances. if it's old and has mineral deposits preventing the piston from moving inside the cylinder, tapping might free it up. or a good soaking in vinegar will dissolve the deposits.
        once the piston is free to move, the water should flow evenly. of course flush out the valve throughly prior to reassembly.
