My piping situation
  • My piping situation
    Hi,
    I’m hoping someone can give me some insight on my pipe situation. I am currently buying the house that I’ve been renting for the last couple of years. I’ve had a few plumbing problems here and there, but nothing too major. I recently had a friend send a camera down one of the cleanouts to see if I need to be concerned. The pipes are about 45 years old. We sent the camera down 80’ and didn’t see anything too alarming. The pics show the worse spots.
    Can someone tell me from these pictures if I should be concerned? I see some corrosion, is that normal? Is there anything I should do in the near future that will prevent any possible plumbing issues down the road?
    Thanks in advance for all your help. I really appreciate it.
ID:	15927Click image for larger version
ID:	15926Click image for larger version
    Re: My piping situation
    Looks like hard water build up....or some kind of scale build up....a good jet job should clean that right up...
    Derek
      jetting will help to descale it. but you have to be concerned to push it out and not suck it back.
      the white crust looks like heavy soap scum or grease.
        Hey Rick, what is the type of pipe. Is it cast iron or steel. 45yrs old, wow........!!!!!!!!!!!
          Smart move getting a video inspection done before you buy any home.
          I'm assuming 60' from the cleanout is still on your property. If not, you may be in the City Sewer Main where it is not your responsibility to maintain.
          Would recommend to get someone to use a water jetter on the main line and while they are there do the kitchen sink line also if that amount of grease is in the main, especially if there is any considerable horizontal distance from the kitchen sink to the rest of the plumbing in the home. Then do another video inspection to make sure they got it all out and to check what is under the buildup.
          Be well,
          Rich
            Originally posted by traceyinsd View Post
            Hi,
            [ATTACH=CONFIG]16324[/ATTACH][ATTACH=CONFIG]16323[/ATTACH][ATTACH=CONFIG]16325[/ATTACH]
            Doesn't look like you have any corrosion... I would say it's more build up then anything.
            If you're concerned make sure you get someone professional to clear it up.
