in trouble
  • in trouble
    Got an older model 1065 black motor with electric foot switch not the air peddle ,long story short I was ridding a main line yesterday and I popped the breaker so I go to flip the breaker and not realizing that the foot switch was stuck down so when I went back outside I noticed that the drum was spinning very very slowly and where the belts are at I seen white grey smoke ,do the motor still turns on but again extremely slow then smokes ,I think its the aremeture or is it the entire motor that's shot any input would be awesome
    Re: in trouble
    That electric switch is gonna wrap you up
    Its time for a upgrade
      Re: in trouble
      My 1065 doesn't pull enough to trip a breaker. I think you lost a motor.
        Re: in trouble
        thanks budd so I should upgrade to the conversion kit then I seen one on Spartan .com for 650$ but I was wondering if I should drop it off at Allan j Coleman on the northside,and see what the also sudgest...
          Re: in trouble
          Thanks^
            Re: in trouble
            GO TO THIS SITE AND MAKE A 800 CALL YOU GET A MUCH BETTER DEAL WITH A TWO YEAR WARRANTY ON THE MOTOR
            800-392-4902
            http://trojanworldwide.com/stallion.html
            YOU WANT TO ORDER BOTH MOTOR AND THE GEAR CASE TOGETHER IT WORKS MUCH BETTER FOR YOU THAT WAY
            JERRYMAC
            E-MAILJERRYMAC777@GMAIL.COM
            FIRE SPRINKLER CONTRACTOR,
            SINCE JAN. 1989
              Re: in trouble
              I bought the motor frame assembly ,came with the motor,gfi air foot switch and new belts ,have to admit very quiet but seems like it lost a little bit of power or maybe its just me I prefer the old screamer personally,now I think I'm just gonna get a ridgid k750 easier to move arround but unsure of the power does anyone use one or should I stick with the 1065
                Re: in trouble
                Glad to see you get the upgrade !!!
                I never ran a ridgid machine cant say
                I know When you take your foot off the switch you want it to STOP
                  Re: in trouble
                  The k750 is not much good for anything other than soft matter obstructions,get the k7500 it is a much better machine.I miss my old k6800 it was an unstopable beast!!
                    Re: in trouble
                    Thanks for the info,love this machine
                    ,tough on the back ,but roots don't stand a chance.
