bronze fittings and copper fittings
  • bronze fittings and copper fittings
    when will you use bronze fittings, such as cast bronze tee, when will you use copper tees in drink water system and in hot water heating system?
    Re: bronze fittings and copper fittings
    you have your terms mixed up, plumbers do not use bronze pipe fittings they use " brass " fittings
    if i am running a copper water system then i use all copper fittings
    but if you are talking about a hydronic heating system then i might use brass fittings
    the main difference between the two is cost as the brass cost more
    on the other hand if i was trying to finish a solder job and all i had was brass fittings then i would use them rather then taking time to go get copper fittings
    JERRYMAC
    E-MAILJERRYMAC777@GMAIL.COM
    FIRE SPRINKLER CONTRACTOR,
    SINCE JAN. 1989
