Source for glass pipe?
  • Source for glass pipe?
    Need about 4 feet of glass pipe with an OD of 1 inch for a custom LED light fixture. I can not find anything reasonably priced to consider. When I Google glass pipes I get -- head shops
    Re: Source for glass pipe?
    Cut the ends off a 96" fluorescent tube?
      Need something with a bit more side wall thickness.
        There's multiple suppliers for laboratory glass, but that stuff's expensive. Lexan or plexiglass won't do?
        Here's a source for plexiglass tubing that might interest you...
        http://www.delviesplastics.com/mm5/m...lexiglass_Tube
        BTW... Google "glass tubing" to eliminate the head shops.
          Local smoke shop??
            crack kills
            just teasing with ya.
              Instead of using pipe in your search, use tube.
                found glass tubes on amazon
                  Most heating suppliers that sell parts for steam boilers will have that. They also have the tools and will cut it to size fot you.
                    try Spears(.com)
