Viega heat pex pipe
  • Viega heat pex pipe
    we are doing a heat job in an old house and we need to fish pipes to get to some of the places . we would use Wirsbo pipe but we cant find it any more because they were taken over by Uponor and we cant find a place that has the new stuff
    so we are looking into the viega pex to use . has any one used it for running heat lines and how do you like it
    do you use the FostaPEX Tubing or the ViegaPEX Barrier
    Re: Viega heat pex pipe
    Viega makes a good product. Stay away from the pex fittings requiring o-rings on the pex fitting itself...can't remember any of their names....sorry. Make sure you use their fitting or it may void warranties.
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
      Do you guys have REHAU over there. Havent used it for heating but would suggest that it is no different to all other REHAU products, bloody good kit.
        Yes, we have Rehab, also a good product.
        AllurePlumbing.com
        • leak detection
        • drain cleaning
        • utility locating
