Viega pex press and pex crimp
  • Viega pex press and pex crimp
    Can any one tell me if you can use the same pipe for either type of fittings
    We are running Radiant pipe and i was wondering if you can use the pipe on the fittings
    and are the pressing tool the same as the crimp tool
    thanks
    Re: Viega pex press and pex crimp
    Any of the Viega pex pipe including the barrier type for heating can be used with either press or crimp and the fittings are the same. Viega did just come out with new black plastic press fittings which are cheaper than bronze. The tools are different for press and for crimp. The Viega Press system is much superior vs the older crimp style. I was told Viega will be phasing out the crimp style in the future.
      thanks because i got some of the propress baseboard kits and the fitting that comes with it is a crimp fitting and we just got the jaws for the pex press fittings .i do not want to tell the boss he needs another set of jaws for the crimp
        I'm not sure of these pipes. But I usually use PVC pipes in fitting process.
        How to find the Best Australia Plumbing Services?
