Did water heaters have 2-inch flues at one time?
  • Did water heaters have 2-inch flues at one time?
    Seeing Hosh's photo make me wonder.
    Re: Did water heaters have 2-inch flues at one time?
    I have only seen it on power vent models.
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
      Good thing they have that basement window cracked open!
        That's a 4"x3". Pretty sure at least. 2" would be tiny. I'll double check it soon. Now it's all 4".
          Is that a water pressure gauge installed on the pipe? I won't mention about the vent being reduced in diameter
            most likely a thermometer. the ones i use from raypak are a combination temperature and pressure with 2 needles.
            a gravity/ atmospheric vent water heater never came in 2''. they don't sell 2'' metallic vent pipe. single or double wall.
              Right on the money as usual.. it's a thermometer.
                Water heaters need venting?
                Ideal Plumbing
                  Yes, it's not bad if your water heaters need to vent.
                  How to find the Best Australia Plumbing Services?
