best sink basket strainer to use
  • best sink basket strainer to use
    I own and maintain and remodel a lot of my duplexes. have been replacing the kitchen sinks and installing new ones. I have been using basket strainers the kind with the big ring on the bottom that you have to tighten. I use plumbers putty between sink and basket, and rubber gasket and fiber washer on the bottom side of sink before the nut. I even bought a special wrench that is made for the big nuts on the basket strainers to tighten it.
    I tighten it tight but sometimes after a few months I get a call from a tenant that the sink is leaking from the basket strainer. what gives??? are they using some super soap/cleaning products that dissolves the putty??? it is probably an error on my part, but i swear i tighten the hell out of it. i keep the strainer from turning with a pair of needle nose pliers and tighten the nut as tight as i can while the putty oozes out. then i remove the oozed out putty.
    Am i buying to cheap of a basket strainer?
    I see they have basket strainers that take three screws to tighten and hold in place. Also I see there are double cup basket strainers where there is a bowl thingy that goes under the strainer and then a smaller nut that holds it up against the bottom of the sink. Are either of these types better?
    Re: best sink basket strainer to use
    here is a picture of the double cup strainer
ID:	626877here is the wrench i am using
        The best basket strainer is Dearborn Brass 816 its a brass body with a brass locking ring.
          Wolverine Brass has a good quality cup strainer and a good price. If you order enough you can have them engraved with your company name on it. Brass lock nut, heavy brass slip nut and a good rubber washer.
          AllurePlumbing.com
          • leak detection
          • drain cleaning
          • utility locating
          • conductor fault locating
          • and other specialties.
            Any links to the ones you recommend?
            Are double cup strainers or the ones with three screws better? What are the advantages over the two?
              I like the one with 3 screws for stainless steel. Any of the brass bodies for a high end install.
              Also, I use silicone instead of putty. The only thing putty is used for are toilets.
                http://www.dearbornbrass.com/Submittals/816.pdf
                  The 816 for Cast Iron sinks is pretty good, but for all around versitility I prefer a cup strainer like the 15BN.
                  http://www.dearbornbrass.com/Submittals/15.pdf
                  Hercules makes a really good non oil base putty
                  http://www.herchem.com/specs/ULTRA.pdf
                  Sioux Chief has foam rubber gaskets that are pretty sweet.
                  Sioux Chief
                    How long do you have to let the silicone dry before the sink can be used again. I can't always trust my tenants to not run the water while the silicone is drying.
                    My sinks are all stainless steel.
                    Does anyone else use silicone instead of putty?
                      Water is a catalyst for silicone. It doesn't take long. By the time you are done with the installation, run a little water through, and you could probably fill the bowls up to test.
                      AllurePlumbing.com
                      • leak detection
                      • drain cleaning
                      • utility locating
                        Yep, you can run water pretty much right away.
                          Wow! I had no idea about that with silicone. Can I use a tube of caulk silicone. Can I use the GE kitchen and bath silicone 2 caulk?
                          Also, is there an advantage over the strainer with three screws vs a double cup strainer. Or is it just personal preference?
                            I dont use silicon or putty for a kitchen sink. the manufacturer provides that thin black gasket to be used for just that purpose, and I never have had even one leak related to that.
                            I prefer this one, similar to the others shown. http://www.kindred-sinkware.com/grfx...specs/1130.pdf
                              Kohler duostrainer. Nuff said.
