Sump Pump
  • Sump Pump
    I'm building a new house and my builder is using a Zoeller sewage pump as the primary. I'm not convinced that is the proper pump. I've also had them install as secondary pit which will be for over flow.
    I do however live in an area that has had several record breaking floods in the last 5 years.
    I need suggestions on pump configuration, primary and backup. I also wanted to use StormPro brand pumps, thoughts on those would be appreciated.
    Re: Sump Pump
    the zoller 267 2'' sewer ejector is a very popular pump out here. just installed 1 a few days ago in a garage for storm water. 3 year factory warranty. make sure to drill the 3/16'' vent hole below the check valve.
      Re: Sump Pump
      Thanks Rick, do you have any recommendations a backup/secondary pump?
        Re: Sump Pump
        They make some that run off of water pressure or hook one up to a marine battery system.
        AllurePlumbing.com
        • leak detection
        • drain cleaning
        • utility locating
        • conductor fault locating
        • and other specialties.
          Re: Sump Pump
          I think this pump is good also DNJ ENGINE WATER PUMP
          How to find the Best Australia Plumbing Services?
            Re: Sump Pump
            Whats your particular reason for using Storm Pro? Have you never experienced other brands?
