Squeaky toilet fill?
  • Squeaky toilet fill?
    New ball cock assembly ? Thanks Ps old angle stop was leaking 6 weeks ago. Installed compression 1/4 turn N S.S. hose
    Re: Squeaky toilet fill?
    Not sure what the question is but, if your fill valve is squeaking, it's the diaphram in the ballcock and likely happens at the end of the fill cycle. I prefer not to use the ballcock type fill valves anymore for that reason and that they don't fit every tank you run into. I use the Fluidmaster Pro45B and have very few issues with it. But, everything fails at some point.
