18 " expansion tank distance min., off wh
  • 18 " expansion tank distance min., off wh
    This to protect rubber bladder from possible heat rise ?
    Re: 18 " expansion tank distance min., off wh
    Great question! Most tanks are rated very high. Higher than most any temperature you will see in residential applications. You will get a much longer life from one, that's about it.
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
