Urinal drain
  • Urinal drain
    Hey gang I have an old crane floor mounted urinal , resting on a 2" cast iron pipe , I recently found a crack in the lining of the cast iron , my question is is there a product you know of that slides down the inside of the pipe ( compression , o-ring PVC pipe ) ! Really don't want to remove due to the age of the school
    Re: Urinal drain
    there has been some success with lining 2'' pipe. but first the pipe has to be throughly cleaned and descaled. there is also a process of spraying and epoxy paint on the interior of the pipe that will help seal the line.
    check with the local pipe lining companies for thier take on it. of course a video is typically required to properly bid the job and verify it's doable.
