Washing machine sink or standpipe ?
  • Washing machine sink or standpipe ?
    Someone said " When You change out that old Wash. Machine with a new one, Junk the plastic sink, and go with just a standpipe. The new machines put out water so fast sink will overflow! " You agree ?? tanks tool
    Re: Washing machine sink or standpipe ?
    The tub has a much higher capacity than the stand pipe.
      I never see anything but stand pipes here
      2" trap 2"riser 36" off the floor
        The new front load washers put out a lot less water and wouldn't even fill a single bowl sink.. We mostly have double sinks in the basement around here and you can't overflow them unless you have a stoppage. Using a single or a double sink for your washer is like insurance if you get a stoppage, it's not going on the floor with one wash.
          Mark, I am doing some work for a real estate Gal. She was told this by a home inspector. Thanks this was My exact thought!
            old school had laundry trays with a 1.5'' trap and sink strainer. the sink handled the water and would then drain just like a bathtub. see lots of old school 1.5'' waste lines that had the sink removed and they connected to the laundry tub 1.5'' drain line. of course with no sink, it requires a 2'' waste line and trap. of course the new h/e machines don't put out near the gpm as the older non h/e machines do.
