NEW 50 Gal Bradford White Gas 3 " existing chimney FOAM ROOF
  • NEW 50 Gal Bradford White Gas 3 " existing chimney FOAM ROOF
    Would up size to 4 " ? Foam will have to be redone in area if upsized. straight up chimney, 5'
    Re: NEW 50 Gal Bradford White Gas 3 " existing chimney FOAM ROOF
    You asking or telling?
    Vent type will dictate minimum requirements. If it needs to be redone I would use single wall vent pipe as your make shift thimble for your air gap.
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
