CO2 Pipe: Water in the line
  • CO2 Pipe: Water in the line
    Hello,
    I have an issue where I'm getting water/ condensate in one of my 1/4" CO2 pipe-lines from my bulk tank to my incubator system. We've tried to blow dry the line but it only seems to last for a few days and then the issue recurrs. We are holiding pressure so we don't believe we have a break in the pipe but short of doing a chasedown on the pipeline we are scratching our heads. Anyone have any thoughts or solutions?
    Thank you.
    Ryan
    Re: CO2 Pipe: Water in the line
    Try pulling a vacuum and use a micrometer. If there is a leak you will know for sure and faster than using pressure. Added bonus is it will dry out the system.
    Another solution is to get a tracer gas and a sniffer.
    Let us know your results!
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
