OK to place Insulation around copper piping in wall?
  • OK to place Insulation around copper piping in wall?
    Assuming the pipes will not likely leak in the years to come, I am stuffing fiberglass insulation in the walls above the perimeter of the bathtub before installing the three pre-fabricated shower walls. This is for sound control. Is this all right? The copper water pipes in the wall are wrapped in foam insulation. The fiberglass insulation competely fills the walls between and behind the studs.
    Re: OK to place Insulation around copper piping in wall?
    nothing wrong w/ that at all
      Even in Warm country , I insulate drop in bath tubs to hold the heat in. Momma likes a nice loooooong hot bath.
