1/4 turn wall hydrant repair
  • 1/4 turn wall hydrant repair
    I have to repair 2 JR Smith wall hydrants with 1/4 turn ceramic disc cartridges. They give you a deep well socket in the repair kit. I used my 3/8 extensions to loosen the existing cartridge, but I can't get it out! Any suggestions on what to use to pull the cartridge out the rest of the 14"? The cartidge is brass, so a magnet won't work. Best I can think of is to try and weld some extensions on a pair of needle nose pliers, but there has got to be a better way. What am I doing wrong?
    Re: 1/4 turn wall hydrant repair
    Put a cap on the hose threads, have someone stand in front of the hosebib with a trash can and throw the water back onto it. That or buy one of Gears plungers.
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
      thanks!
        I've done the "turn water on to remove cartridge trick". Be aware what the cartridge can hit when it comes out. In my case I put a dent in a car parked across the sidwalk.
          sounds exciting !
            Originally posted by toolaholic View Post
            sounds exciting !
            Keeping in mind what Ben said, the smaller/thinner the trash can the more exciting it could be.
            AllurePlumbing.com
            • leak detection
            • drain cleaning
            • utility locating
              both were adjacent to parks so no worries about damage. Both are good to go now
              Thanks again.
