Want To Add Wash Sink In Garage--How To Drain
  • Want To Add Wash Sink In Garage--How To Drain
    I want to add a wash sink inside my garage. On the opposite side of the wall where I want to add the wash sink there is an inside bathroom sink. See the two different diagrams below for existing setup. What I want to do will be in my next post. Both drawings have the same plumbing...just different views
    Re: Want To Add Wash Sink In Garage--How To Drain
    I'd like to see if this is the correct way of adding in a drain for a slop sink in the garage based on the existing plumbing in post #1.
    San-T "A" in the diagrams below would be the stub out for the garage slop sink
      Or what about this setup...similar to post #2 but now
      -the San-T at position "A" is turned to the left,
      -use a Wye on its back(fitting "F") with a Street-90(fitting "G").
      -the Street-90 would pick up the slop sink.
        Originally posted by Martin 4
        The location of my garage is very old type,I want to add wash sink in garage.The bathroom sink is insideout.Plumber can better tell me about this.Plumber have showed me some drawings which i will show you in the next post.Realy i want my garage clean.
        Do you have a similar ssituation or are you trying to be funny?
