Possible slab leak?
  • #31
    Re: Possible slab leak?
    sorry about the english, most contractor dont spell very good, including me. The i5 will see the heat of the slab and tell u the temp of the area, it dont look under the slab only on top and heat change.
    I also located with the sonde to make sure the pipe is under that heat area, my customer pipe hair like crack is not from the bottem this is why i dont see water, it is hair line crack from the side so the water would run good and no clog, camera would not see the hair line crack, my customer say it been hot for over a year and they check the meter and meter is not turning, only after a year later they found out the meter is turning and they got high water bill, so it is slab and sewer leak on that job we did.
