Can you tell me why....????
    Re: Can you tell me why....????
    I think it's a good idea. I have thought for a long time all over head c/o should have a valve on the them
      Might be handy at times but DOI would never approve.
        sump pumps are required to have a shut off and check valve. the valve is there to isolate the check and pump from the wash back of the drain line running above.
        problem is a typical ball valve or gae valve is not engineered for common gravity drains. if they had recessed threads, and a smooth porting, then it should have no ill affect on a gravity system.
