Recirc. Pump 24 hrs 365 days a year ???
  • Recirc. Pump 24 hrs 365 days a year ???
    This residential home is about a 1960 Eichler ,slab on grade. The Plumber that installed the system did this. He reduced the 3/4" copper to 1/2" before the pump. Cavation wore through the 1/2 " at the pump head and top pump fitting . I want to go with a grundfos home comfort with timer and Temp clip. I am worried about the under slab copper developing leaks ! Was told to only change out 1/2" to 3/4". How would You handle this one ? Thanks Kevin
    Re: Recirc. Pump 24 hrs 365 days a year ???
    that's about the best pump for that application. you can't be responsible for the piping that's already paper thin. just put it all in writing and cya.
    do they really need a pump? leave the system off for a couple days and have them report back to you.
