can vent go down few inch?
    Re: can vent go down few inch?
    cut the nipple and leave approx 1.25'' of pipe sticking out from the 90. also cut out the old tee. install a sanatary tee at the upper cut and band it to the stub. this will put you as high as possible. fill in the gap with a section of pipe and band it to the riser.
    are you using abs , pvc, or cast iron no hub?
    I will use PVC.
      Call Plumber. Get inspection. Good Luck.
        Move the door over a couple of inches.
