Fire Sprinkler systemdesign concept
  • Fire Sprinkler systemdesign concept
    Just want to know a little idea as to how many sprinkler heads can one i connect with a 4" dia line, 3" dia line, 2" dia line and so on. Would be great if someone could share it in a tabulated form, like making a table and putting different dia lines and sprinkler heads against each. I am after a small warehouse firefighting designing and intend to install a fire sprinkler system there. Thanks
    Re: Fire Sprinkler systemdesign concept
    are you serious
    you're the mechanical engineer and you haven't a clue on how to size a sprinkler system.
    do you even have the knowledge to know the pressure, pressure drop, developed length, head loss and so on.
    i normally more than happy to help a non pro, but if you don't know what you're doing as a pro, go back to school.
    am i the only one that's critical on this
      see post #7 this sums it up.
      https://www.ridgidforum.com/forum/t42423/
        are you serious
        No Rick. It's what I've come to expect from an "engineer".
          Although not legal now for a new system, pipe sizing was determined by the number of heads. There was several limiting factors on the water supply though. This was called pipe schedule systems and is still legal if you are adding onto an existing pipe schedule system. First the hazard had to be determined (light hazard, ordinary hazard or extra hazard) then you had tables to tell you how many heads could go on what size pipe.
          Now days all of the input is plugged into a computer program and you will decide what size pipe according to friction losses and velocity pressures.
          That is as far as I am willing to tell since you are a mechanical engineer and I am just a peon designer (read this as siding with Rick)!!
            Originally posted by g3sprinklers View Post
            although not legal now for a new system, pipe sizing was determined by the number of heads. There was several limiting factors on the water supply though. This was called pipe schedule systems and is still legal if you are adding onto an existing pipe schedule system. First the hazard had to be determined (light hazard, ordinary hazard or extra hazard) then you had tables to tell you how many heads could go on what size pipe.
            That is as far as i am willing to tell since you are a mechanical engineer and i am just a peon designer (read this as siding with rick)!!
            2nd this as a fire sprinkle contractor
            JERRYMAC
            E-MAILJERRYMAC777@GMAIL.COM
            FIRE SPRINKLER CONTRACTOR,
            SINCE JAN. 1989
              So Rick does that mean you won't be sharing the data in tabulated format?
