Installation of Moen 1224 Hot Water Cartridge
  • Installation of Moen 1224 Hot Water Cartridge
    When I install the Moen 1224 cartridge on the hot water side, I get no hot water at all. The red entension stem is installed and when I turn either way, I do not see the opening in the cartridge. What am I doing wrong?
    Re: Installation of Moen 1224 Hot Water Cartridge
    is the extension stem stripped or broken?
      I found my problem. When I was removing the handle, I must have rotated the entire assembly, hence the hose under the sink was pinched. After I rotated the assembly back to the correct position and un-pinch the hose, the hot water started to flow.
        pretty common on a wide spread. in the old days you would have ripped out the copper connectors. some of the newer faucets have a spring in the hose to prevent this.
