washing machine valve box
  • washing machine valve box
    what are the 2 capped pipes that tee off the supply lines for? something to eliminate water hammer? if you needed to replace the valves would you replace all the pipes shown in the photo? Seems like it would be difficult to cut the lines connected only to the valves.
    Re: washing machine valve box
    Air chambers. Never seen it done that way.
    All fixtures with quick closing valves (i.e. solenoids) should have shock arrestors.
    Those particular hose bibbs look like they can be unscrewed for replacement.
      those are poor man's water hammer arrestors. they are not needed in cases of a well system or where an expansion tank is installed on a city water system. the more common ones are screwed in and look similar to CO2 cartridges as used in paint ball guns.
        Will the water hammer arrestors eventually fill with water?
        Will the air in the pipes be absorbed into the water and they will fail to minimize water hammer?
          Re: Will the water hammer arrestors eventually fill with water?
          Have to think that it would happen eventually, especially if there is pressure. this photo give rise to memories of salesmen at suppliers and the bs they tell the weekend warriors whilst extracting copious quantities of cash from them for "remedies' to water hammer
            yes, in a very short amount of time.
            it kills that me they would tell people this since selling them the proper parts would result in a better installation and more profit.
              Thanks guys. This is as installed by the builder. Would you recommend removing and replacing with the valves that have the built in arrestors (made by Oatey) ?
              Also considering adding a laundry tub sink in the empty spot. Would it be OK to wye into the vertical pipe and essentially use the washing machine discharge pipe trap as the sink trap as well or would the sink require its own trap (essentially having 2 traps in line before the ejector pit) ?
              I guess the 3rd option is for the sink to have its own trap and then tie that in after the existing washing machine trap
