Can anyone identify this water service line?
  • Can anyone identify this water service line?
    I am buying a home and I think it may have a polybutylene service line. All of the distribution is copper so no worries there. Thanks for the help.
    Re: Can anyone identify this water service line?
    it has a polybutylene connector. the service line *may* be PB line or it may not. we can't see it here in this picture. PB line is most commonly known for the class action lawsuit involved. It goes under a few names but Qest or Quest is the one I'm familiar with.
      [ATTACH=CONFIG]17623[/ATTACH]
      Just guessing but the tubing is copper. The grey is Quest Repair Fittings for Copper, CPVC, PEX and Polybutylene
      POLYBUTYLENE repair fittings - PlumbingSupply.com
        Thanks. I opened up the meter box and the pipe was caked with dirt. I scraped a section off and it appeared to be gray as well.
          I was about to suggest that.
          If it's grey and scrapes like plastic then it's probably PB line. The previous homeowners or the township may have records regarding this as well.
            ...if it is indeed polybutylene i didn't realize it could be trusted underground. jmo
              Originally posted by arizonaplumber View Post
              just guessing but the tubing is copper. The grey is quest repair fittings for copper, cpvc, pex and polybutylene
              polybutylene repair fittings - plumbingsupply.com
              you are 1 smart monkey !
