leaky faucet
  • leaky faucet
    i have a
    Pfister Pfirst Series White 1-Handle Pull-Out Kitchen Faucet on my sink and it drips all the time. What washer do I change to make it stop. Tell me how to get to it, please.
    Re: leaky faucet
    How about a pic?
    Derek
      Re: leaky faucet
      You need to remove the little red/white plug on the handle. Then Remove the handle. Remove the lock nut below, then remove and replace the cartridge. This is all assuming it is a single handle faucet.
        Re: leaky faucet
        price pfister requires a price pfister cartridge. depending on the age, there are 2 different types of cartridges. remove the handle and post a photo or color of the cart. also call up price fister 1-800- pfaucet, and they will send you a new cartridge. also make sure they send you a brass locking ring as the plastic factory one will probably be destroyed when you try to remove it.
          Re: leaky faucet
          Probably should mention to check the shut off valves under the sink first to see if they work.
