Installing Utility Tub w/ Pump Into Horizontal Waste Stack
  • Installing Utility Tub w/ Pump Into Horizontal Waste Stack
    I’d need to install the utility tub as per the photograph, or alternatively tie the washer in to the left of the dryer (to the left in the picture and where there is a clean, horizontal run) and place the utility tub where the washer is. The only item that can’t be moved is the dryer. As you can see, I’ve got the utility sink and the pump. The down pipe far left is waste, the middle is vent (I believe), and the right is waste.
    I’d like to avoiClick image for larger version
ID:	635683d tying the pump into the drain where the washer drains, and have the washer drain into the tub. I've though of a few different ways to do this, but I want to make sure I'm within code.
    Thanks so much for your help.
