cutter wheel for vintage Ridgid pipe cutter
  • cutter wheel for vintage Ridgid pipe cutter
    I need a new cutter wheel for a Ridgid pipe cutter I bought used, but I cannot find a model number on it.
    I have Googled all the pictures online for Ridgid pipe cutter, and searched eBay,and no luck.
    It is 14" long, weighs 10 pounds, seems to have a maximum jaw opening of 2 1/2", but it differs from most Ridgid products in that the cutter is at the end of the feedscrew, and the rollers are in the main casting.
    When it is turned, the feedscrew handle remains next to the main casting (body), and the feedscrew is not exposed at all until the cutter is fairly close to the rollers. To say it another way, the overall length of the pipe cutter never varies, it is always about 14" whether the jaws are all the way open or all the way closed.
    The body casting looks most like the Ridgid 821 Blade type, but my model has a cutter wheel, not a blade nor does it have all the other blade type parts.
    Pictures attached.
    The cutter wheel currently installed is marked "Ridgid 500".
    I need a cutter wheel for galvanized pipe.
    Thanks for your help !
    Re: cutter wheel for vintage Ridgid pipe cutter
    Looks similar to the cutter on an older pipe machine.
      Looks like a cutter off of a 535 threading machine.
        Try this
        Pressing Technology - RIDGID Professional Tools
          It uses a e 1032 cutter wheel. Marvin
            Support - RIDGID Professional Tools
            You beat me to it.
            See the link for #2 part numbers.
            Rick.
