Connecting electric water heater to CPVC Page Title Module
  • Connecting electric water heater to CPVC
    Can I use a female CPVC adapter directly to the galvanized nipples on the electric water heater?
    Re: Connecting electric water heater to CPVC
    yes, but i would suggest CPVC unions for ease of future work.
      Thank you for that advice. One other question. My water heater will be on the same level as the fixtures it supplies. Should I use a vacuum breaker?
        you can. use what your building/plumbing code requires. contact your town department for that information.
          i dont like the all cpvc female adapters,,,,ive seen a lot of split ones,,,,,,, i would recommend the brass female adapters with a built in cpvc ,,,a transition fitting so to speak.
            My experience exactly
              It's always better to thread male plastic into a female fitting, preferably brass in this case.
