How bad is this expansion tank location?
  • How bad is this expansion tank location?
    Hi,
    I just recently noticed that the expansion tank in my house is installed like so
    main water shutoff valve - > Pressure Relief Valve -> expansion tank -> cold water shutoff valve to water heater -> water heater
    but from everything I've read it should be
    main water shutoff valve - > Pressure Relief Valve -> cold water shutoff valve to water heater -> expansion tank -> water heater
    Just how bad is it that it's not installed the latter? Is this something I should immediately fix?
    Thanks everyone!
    Re: How bad is this expansion tank location?
    It's fine if you never shut off the source to the hot water tank and leave it in operation. Fix it at your leisure.
    Do you really have a pressure relief valve in the water line or is it a reducing valve? Is it a reducing valve with backflow prevention?
      Sorry, it's a pressure reducing valve! I guess I wouldnt really turn shut off the source to the hot water tank and leave it in operation, but from what I'm reading it would be nice for when the expansion tank needs replacing.
        When the HWT goes bad, move and replace the expansion tank.
          There is nothing wrong with the location it will do its job. When replacing water lines here we have to install an expansion tank when there isn't one on the water heater. Sometimes depending on location it is better to put it on the main.
          AllurePlumbing.com
          • leak detection
          • drain cleaning
          • utility locating
          • conductor fault locating
          • and other specialties.
            Awesome. Thanks!
