sewage pit bottom cracked Page Title Module
  • sewage pit bottom cracked
    I discovered my sewage pit in my basement has cracks in the bottom. The lining is plastic. Any suggestions on fixing. I would like to put a new bottom in if possible.
    Re: sewage pit bottom cracked
    are you sure it is a sewage pit,,,,,,or could it be for drain tile,,,,,,,,,,,or cold it be for laundry waste??? could the pit be made of fiberglass
      It is a sewage pit for my basement bathroom. I discovered the cracked liner when I was changing my sewage pump out. I was just wondering if anyone had a unique fix to this situation.
        A simple fix is to pour about 1" of hydraullic cement. Pourstone comes to mind. You could try fiberglass and resin, just not sure about the bond to a plastic tank.
        Another fix if it's a perfectly round tank is to laminate a sheet of plastic, acyrlic to the bottom. Plenty of epoxy or rated construction adhesive to seal it in.
          I like the hydraulic cement idea.
          David
            Thanks Rick! I'll give the hydraulic cement a try.
