I see a lot of TOTO 3" falpers go bad Why? Many Kholers too. What is the weight on a 3" flap in a tank. Do you figure by the whole tank at 8 lbs per gal or only a 3" cylinder however high the water level is?
TOTO math?
Re: TOTO math?
the idea is a quick strong flush instead of a longer weaker flush.
the newer flappers for the 1.28 have the float. the 1.6 still have the chain and some have a hard plastic tube over the few links of chain.
the red is the g-max flapper and the blue is the power graviy. i think the green is the newer cyclone flush.
rick.phoebe it is
Re: TOTO math?
Just the 3" cylinder
Originally posted by Reardon View PostI see a lot of TOTO 3" falpers go bad Why? Many Kholers too. What is the weight on a 3" flap in a tank. Do you figure by the whole tank at 8 lbs per gal or only a 3" cylinder however high the water level is?Originally posted by NHMaster3015No, it's not rocket science, it's plumbing and unlike rocket science it requires a license.
Re: TOTO math?
Originally posted by Dhal22 View PostI've installed a few hundred Toto's and don't recall a lot of flappers going bad.
David
Re: TOTO math?
Originally posted by cheesehead plumber View Posti had my first service call on a skirted toto toilet,,,,,,,,kohler is king in wisconsin,,,,,,the homeowner informed me that it was only 3 years old old,and leaking on the floor,,,,,,not leaking around floor seal,,,,not a wax ring on this model,,,,found water leaking threw concealed trapway,,,,so this toilet bowl is junk ,,,,,,only 3 yrs. old. my ??? is what has been your experience with leaking toiet bowls on toto toilets with skirted bowls????
Re: TOTO math?
I prefer to check a toilet install, then recheck, then triple check, then quadruple check, then check again. Eliminates a lot manufacturing defects, forgotten steps, loose connections, etc. I've installed a few Aquia's, etc, never a problem.
David
