power vent
  • power vent
    i am having problems with my power vent on top of my gas water heater....it keeps running with no flame...i cleaned everything ...it works till i put the top cover on back on the power vent,flame goes out...take it off and runs fine...can a sensor be blocked,can it be cleaned and replaced or replace new...ty,greg
    Re: power vent
    Need a lot more info than what you've provided. Make, model of the heater for starters. What exactly have you cleaned?
      Re: power vent
      american water heater co.....powerflex.....model #pvg62 40t50 3nv....cleaned hose going in to air pressure switch..motor etc.
        Re: power vent
        Best guess, is the gas valve telling the motor to run. Call a plumber
          Re: power vent
          i don,t think so....i am going to change the air pressure switch...and i am no plumber.....any more ideas????
            Re: power vent
            I wouldn't just randomly replace parts without properly diagnosing the problem. The installation instructions show you how to troubleshoot the pressure switch and other parts related to your issues. When was the last time you oiled the fan motor?
            http://www.americanwaterheater.com/s.../powervent.pdf
              Re: power vent
              The pressure switch does not CAUSE the motor to run, it ALLOWS a firing circuit to be completed via proof of draft. With the HWT assembled as normal, if the fan runs and the firing circuit will not engage check the pressure switch for proper voltage at both terminals (terminal to ground). This will tell you:
              - proper voltage is present at both terminals
              - the pressure switch is operating correctly
              - the pressure switch is passing proper voltage
              If you have proper voltage at one terminal and not the other then the switch may be bad or your venting may have issues. Check for:
              - plugged termination
              - debris in vent
              - plugged air intake (common)
              Other problems may include a bad control valve or bad external limits. Changing parts willy-nilly is not a smart or proper course of action. Call someone with the experience diagnosing and working on this unit.
                Re: power vent
                thank you.....wow..i never oiled the motor until this week....i will have the switch checked before i change it...will stay in touch guys...thank you all...until later have a great day !!
                  Re: power vent
                  Whose money do you count?
                    Re: power vent
                    Originally posted by plumbus View Post
                    whose money do you count?
                    " the plumbers "
                      Re: power vent
                      mohegan sun pocono downs,pa. slot and table games .....
