How To Post Images
See more
See less
Drain tile/French drain cleaning?
  • Drain tile/French drain cleaning?
    Thirty year old interior drain tile clogged up and not flowing.
    A bit different than a main or branch line. Looks like 3" coming into the sump basket.
    Any experience out there? Jet? Not going to put my K-60 in. No camera.
    Prefer not to dig.
    Thanks
    Re: Drain tile/French drain cleaning?
    Jetting would be the easiest, fastest, and would clean the best IMO.
      X2^^
      Probably full of mud. Snakeing will do very little and risky. Jetting by far the best option in this scenario.
        Thank you for your input.
        Has anyone actually jetted drain tile.
        Also wondering if in other parts of the country drain tile or also called a French drain
        consists of the same material.
        Would jetting force the mud back down the perforations and just seal them up?
        With Spring thaws here and lots of basements flooding it may be a lucrative concept, or not.
        Thanks
          Assume you're referring to perforated pipe? We do septic drain fields all the time with great success.
          In your drain, are the holes up or down? Assuming they would be up in that application?
            Holes or perforations on drain tile/French drain are down to collect ground water.
            That's why I am wondering if jetting will work. Outfits here want to dig.
            Not sure how it works in Drain Fields but thanks for your thoughts.
            One nice thing about flooded basements is more floor drains need cleaning.
              I have jetted a block of homes. The whole city block hired me to go to each of their homes and jet the drain tiles for them. Only difference is these all had clay drain tiles., The clay pipes are laid in a trench with a 1/4" gap between each pipe then stone all around. When I was done the lines were flowing nice and free.
              I also jetted the corrugated drain tiles as well, it too made a huge difference for the home owners. Before jetting I did power rod them, had cutters that would not cut through the plastic corrugation. Had to rod and flush the line with a hose multiple times to get it to run clear. It did not do 100% of a job but did get improved flow.
                jetting is the way i do it. when it comes to mud, roots and gravel, a snake only stirs things up. a jetter liquidfies it and washes it out all at once.
                best bet is to jet from the outlet up towards the high end.
