shower valve broken
    Re: shower valve broken
    This is usually how most remodels start.
      gear junkie - funny you say that, now I am mid-way thru reno.. just kidding. but the mother in law does want to reno the bathroom so it might good timing.
      Jerryman - if i had the money i would have called a "real" plumber in the first place but since I can not afford it, I decided to seek the advise of you fine people.
        Ok here are the other two handles
          Thinking Sterling or possibly Sayco
            Thinking his MIL really needs a reno
              Sayco all the way...good luck...gonna need it.
                Sayco actually makes a heavy duty specialty tub socket to remove that stem. Looks too late to use here though.
                • #23
                  You turned off the water to the house, and opened the valve to release vacuum first, right?
                  • #24
                    JK949 - Yes.
                    So this would be too late?
                    Yes, I know she needs a Reno bad, money is just tight for her.
                    • #25
                      The recessed hex looks okay, I would give it a shot with a deep socket with very little play. A plumber's socket kit isn't the most heavy duty, but the thin walls can fit it tight spaces.
                      • #26
                        The Sayso stem I was thinking of has just two flat sides and rounded on the the others. A typical six sided tub socket set won't fit over it.
                        • #27
                          To me, the body looks slightly crushed like what can happen when you apply a pipe wrench to a weakened pipe nipple. Either a socket will fit or it won't.
                          • #28
                            JK949 - Yes that is what happened, I thought having a wrench of some sort would help since that is what I saw online but when I applied the pressure it broke. I didnt figure it to be so weak.
                            So would it possible to just grab the nipple and with whatever I can and try to turn it till it comes off?
                            A guy at the hardware store suggested a deep socket, one where you turn it with a screw driver but it did not fit. I will post a picture of it.
