shower valve broken
  • shower valve broken
    Hello, I am new here and im sort in a bit trouble. I was attempting to repair my motherin laws leaky shower and in trying to take of the valve I broke it. Can this be repairable or am I screwed??
    Re: shower valve broken
    Depending on the valve brand. Post a photo of the parts and we will guide you to a solution.
    Had to be the mother in law on mothers day
    Rick.
      Rick.
      WOW!! the mil!! better fix that ASAP!!
        Amazing I responded within 3 minutes of his post and no answer, photo.
        Maybe the mother in law got him.
        Rick.
          maybe he broke the camera too
            Lol sorry for the no response, photo something else came up and needed my attention and with it being mothers day my attention was elsewhere. Rick- i got pictures however i am having difficulty uploading them
              I hope this works and I apologize once again for the delay.
                Wow! Usually when I see them that bad they get replaced, unless I can get the parts easily. (What's the brand?) Still, you may need to have rear access to the valve to get the parts to come out.
                  So rear access will be hard since that shower backs up to another shower. is there anyway I can attempt to grab that broken part and turn it??
                    all is not lost yet as i feel all you need is a new stem. can you post a photo of the other stem with trim on and trim off. see if i can id the valve.
                      Maybe vice grips or similar. If you are very careful with a torch, heating the valve body may help loosen the stem. Dont char the walls or start a fire where you cant reach it.
                        Yea i can take a picture of the other side tomorrow and hopefully i can be in my mil good graces.
                        If i start a fire now it would seal my banishment from the family lol.
                        So maybe attempting to turn it can still help??
                          A name on the handles always help. Also a photo of the trim, handles. Along with a photo of the good stem still installed.
                          Is this unique to the 1 bathroom, or is a similar one in the other room?
                          Rick.
                            This set up is only on this bathroom, the other is just a standing shower and uses another set up.
                            I really hope that I can get this fixed since the one I "broke" is the hot water and it's just leaking water so I can only imagine that the water and gas bill will be pretty high is not fixed soon.
                            Too bad this is the MIL. :/
                              Worst case you can always call in a real plumber ?
                              JERRYMAC
                              E-MAILJERRYMAC777@GMAIL.COM
                              FIRE SPRINKLER CONTRACTOR,
                              SINCE JAN. 1989
