schedule 40 to thin wall
  • schedule 40 to thin wall
    will a 4" fernco connect old thin wall to new schedule 40 pvc, or what is the proper way of connecting these two?
    Re: schedule 40 to thin wall
    I assume by thin wall you mean S&D ASTM 2729 PVC Pipe. If so then a 1056-44 Fernco coupling will work just fine.
    Diapers and Politicians need to be changed often... Usually for the same reason.
      You can also get a bushing that glues into a schedule 40 hub to bring it down to sewer size (thinwall) .
      or a sewer fitting of any type will glue inside a schedule 40 fitting.
        i would cut a thin wall cpl in half and glue it on the thin wall pipe , that makes it sch 40 size
          been there done that too.
