device to let air out but not water under pressure
  • device to let air out but not water under pressure
    This is not a plumbing question. But I know you guys not only experts of this area but also familiar with other areas. My research project needs a device which can let air escape but not the water under about 3000psi pressure. I have a container with waters. But air may go in during filling process. The air is not allowed for a particular reason. After close the container, we will add pressure by pushing to about 3000psi. We need the air escapes from the container during this process but not the water. Temperature is room temperature.
    Does this device exist? any name/link will be appreciated.
    thanks,
    Re: device to let air out but not water under pressure
    You can't put a valve at the top of the storage tank and bleed off the air and shut off once water comes out? It needs to be automatic?
      A handyman working on something with 3000 psi?! Do not do anything. What would a handyman be doing with something like this?
      AllurePlumbing.com
      • leak detection
      • drain cleaning
      • utility locating
      • conductor fault locating
      • and other specialties.
        Yes, we try to make it an auto process. If manually bleed off the air. The operator will not be happy and how to know when is time to shut off the valve. The water may come out as well.
          Not actually doing it. Research it. If possible, it will be given to professional.
            Perhaps if we knew the application of this contraption.
            Most of us have the proper security clearance.
            I'm sure Rube Goldberg could come up with something.
              Contact watts company. They have auto air vents that work under low pressure (less than 200 psi) so I'm sure they would have something high pressure.
                it has a float that will seal off the discharge port when the water fills. this causes the float to rise. similar to how a wet dry shop vac works.
                  I have never heard of Watts having anything like it but it is worth the call. I think they stay more residential boilers.
                  AllurePlumbing.com
                  • leak detection
                  • drain cleaning
                  • utility locating
                    it would be nice to know the application as we may have better options than a glorified auto air vent
                      OK all joking aside, what is it for? Try Parker. I know you are not working on a boiler being only a handyman (no offense). There are just not that many places that use that high a pressure and usually engineers are involved. Same with refrigeration system in industrial plants. The only thing really left is air compressors.
                      AllurePlumbing.com
                      • leak detection
                      • drain cleaning
                      • utility locating
                        scuba applications use up to 5000 psi.
                        i found this hydraulic auto air vent - good to 15 gpm and 8700 psi:
                        http://www.hydacusa.com/valves/aev.htm
                        Edit: best price I could find was $71:
                        http://www.plccenter.com/en-US/Buy/HYDAC/00859100
                          Gotta agree with all here, pipe up with the application so we can all give our two-bobs worth(sorry Bob.......!!!!!!!!!)
                          The energy of 300psi in a vessel will blow your bloody head off. Don't know about you but I haven't finished living yet, still want to enjoy a bit more.
                          As far as auto air bleeders, haven't heard of many companies doing them and they are all low pressure.
                          If it is topsecret and you cant share then head for a Mechanical/Hydraulic Engineer(dare I suggest either).................!!!!!!!!!!!!
                            Originally posted by Cleanmen2 View Post
                            two-bobs worth
                            Could you imagine what we could do with TWO Bobs? All the world's problems would be solved, men would be on Mars, the starship Enterprise would be reality, Ridgid would make tools that customers want and the LLSA would be easy and fast...
                              I have to agree. I am more than enough, no need for a second Bob.
