ID this shower valve cartridge please
  • ID this shower valve cartridge please
    It is a least 10 years old.
    Ceramic.
    No names or model numbers.
    Thank you!
    Re: ID this shower valve cartridge please
    What? no takers?
    Looks like a hardware store brand of some kind.
    In that last pic there should be a gasket on the bottom of the cart.
    Might be stuck to the valve body.
    Me, I would replace that valve.
    As long as the cover plate on the new valve is the same size
    or bigger than the original, you can install a new posi-temp
    right in the same hole without cutting tile.
    Would have been nice to see the valve in the wall along with
    the piping. Is the plate grouted in?
      Ceramic.
      Thank you!
      They don't put a name or model number on it , Hopeing you buy their brand again by mistake
        Did you remove the cover plate to see if there was a sticker on the back of the plate? Usually there is a name, and build date.
        My buddy thinks its a no longer made delta spin off company.
        Rick.
          Never play telephone with Rick !
          I told Rick that it looks like something Delta put out about 15 years ago by the name of "Epic". Good luck.
