cast iron baseboard
  • cast iron baseboard
    The existing cast iron baseboasd is too long for my bathroom. I am thinking separate it. Anybody has experience about this? how hard it is. If I cannot make it shorter, can I install it vertically?
    Re: cast iron baseboard
    You can tale it apart but all your going to find is 2 bushings. You need to have an end with threads to put on it. So I would say no you cant make it shorter.
    As far as putting it vertically you can but you will need a bleeder at the top and make sure your return is out the top and supply in the bottom.
    Call around to some heating places and see id they have a smaller one on hand and trade it with them.
      That's a good idea!
      Do you have a good way to join two sections without that special clamp? I will replace the electric heating with the same weil-mclain cast iron baseboard in my living room soon.
        Originally posted by thisnewowner View Post
        That's a good idea!
        The clamp tool speeds up the process but is not absolutely necessary. Be sure the mating sections are clean and that you use new bushings. I use a little Permatex on the bushings. Place face down on a flat surface and block with a 2x4 while tapping together with a heavy sledge hammer. If there's a gap it's not tight enough. Finish with new carriage bolts.
          If you strike out at the heating suppliers, try a salvage yard if there any near by. They may have some taken in as salvage from a demo project.
            I have also used a jack by putting it against a wall and a 2x4 on another wall with the jack. Works well
