how do i remove this cartige?
  • how do i remove this cartige?
    it is a moen product
    any tips?
    what do I replace it with, hot water does not come on
    Re: how do i remove this cartige?
    Shut the water off to the fixture. Either the valve has stops behind the plate, or shut off the building first. Remove the "u" clip at the top of the cartridge. Then the new cartridge comes with a plastic little insert tool to help rotate the cartridge in the valve body. Once it rotates, it should remove by pulling out with pliers. If not you need a moen puller.
    Rick.
      any tips?
      found this vid. hope it helps. http://www.bing.com/videos/search?q=...41&FORM=NVPFVR
        thanks guys good advice like always
